NGL stripping using light gas stream
Hi there;
For a stripper column used for NGL. Can we replace the bottom reboilers by injecting direct light gas stream to the column's bottom?. This new stream is high temperature stream and light MW.
RE: NGL stripping using light gas stream
No way to answer with the information you've given.  What are you stripping out of the NGL?  What is the bottom's specification you are trying to meet, etc.
With what you've provided, the answer is 'maybe'.
