GOUGE & DENTS
GOUGE & DENTS
HI ALL :
could you please provide me with more information about the above subject matter, gouge and dents?
i mean could anybody elaborate on this, give their techanial definitions, if some exist on a peice of pipe how can i deal with or repair it?
and, i would really appreaciate it if one could refer me to good site which gives such a basic info.
best regards;
mohd
best regards;
mohd
RE: GOUGE & DENTS
I suggest that you consult the piping design code that governs your installation. Look under the section that describes "minimum wall thickness" or "calculation of wall thickness" This section will give guideance on the maximum "gouge" size that can be tolerated without repair or replacement.
Look at the section that describes "out of roundness". This will give you some direction on the size of a dent that can be tolerated.
Good Luck !
MJC
RE: GOUGE & DENTS
There are tons of ways to fix these defects. The best is probably to just replace the cylinder of pipe that is damaged. Barring that you can use full-encirclement fittings (bolt-on or welded), patch repairs, and even some composites. You might want to check out:
http://www.plidco.com/
http://www.dressercouplings.com/gas_prod/gclamp_sleeve/gclamp_sleeve.html
http://www.allanedwards.com/steel.htm
http://www.clockspring.com/
Good luck.
RE: GOUGE & DENTS
Another reference i can suggest is the pipeline welding and inspection published by AWS based on the proceeding of Conf Ag 1980. A paper again presented by JK Keifner where he talks about dents and gouges (page 77).
