frelon linear bearing vs igus brand linear bearing
Hello all, New guy here who happened across this site in search of knowledge about linear bearings. Very excited about finding these type forums available, bet I'll be a frequent visitor.
Hope some of you can shed light on the following.
I have a new design linear actuator that I want to use a "frelon" type linear plain bearing on the output shaft. The output shaft will be 5/8" anodized aluminum specific for use with coated bearings.
Igus offers their "iglide" bearings in a number of different materials along with their "Drylin" aluminum shafting. Igus application worksheets are very specific in bearing recomendation for my conditions.
The "frelon" bearings are offered on every street corner it seems as a do all solution for linear motion.
I have looked at those offered by Pacific Bearing along with their "Feathershaft" aluminum shafting.
Is bearing selection all that crucial or should I just use a generic coated bearing and generic anodized shafting?
Thanks to all, Larry (donduck)
RE: frelon linear bearing vs igus brand linear bearing
If this is an aerospace application I sure a generic bearing will not offer the tracability required for your design.  Check www.ggbearings.com.  Garlock offers a number of speciality self-lubricating bearings (DU) and prelubricated bearings (DX).  Without knowing you specific application I will hold back offering any specific technical information.  Garlock's website offering a number of application documents for download.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
The Frelon, Garlock, and Pacific bearings all use a teflon liner, as well as INA's offering. Have you also considered the recirculating ball-type bearings? They do not require aluminum shafts. If so look into Thomson, Lee Controls, IKO, NB andmany other manufacturers
Russell Giuliano
Thanks, heckler and diskullman for the information. Larry Page
