How to run a accelerometer using labview?
I own a SerAccel v5 Enclosed is a 3 axis accelerometer from sparkfun electronics. Its uses a rs232 communication protocol and I would like to graph the real time output of this sensor using labview. Detailed specifications for the sensor are included in the following link. I am a complete beginner at this type of computing so I really need help on this.
http://www.sparkfun.com/datasheets/Accelerometers/SerAccel-v5.pdf
Frank
RE: How to run a accelerometer using labview?
You can request that a device driver be written for this product at http://sine.ni.com/apps/we/niid_web_display.request_driver or attempt to write one yourself.
xnuke
"Do you think you used enough dynamite there, Butch?"
