Temperature Coefficient of Resistance of Brass
I have found the temperature coefficient of copper (.00393 per degree C @ 20 degree C) but I also need the value for CDA 26000 and CDA 24000 brasses. I've searched all over and found several places that state "brass .002" but I need to be more precise than that. I know the alloy will make a significant difference.
RE: Temperature Coefficient of Resistance of Brass
http:/
ko (www.ecooling.biz)
http://www.kayelaby.npl.co.uk/
unfortunately it only lists brass, not alloys of........
26000 TCR: .00153/deg C @ 20 Deg C
24000 TCR: .00161/deg C @ 20 Deg C
My on tests at 20 and 100 degrees C yeilded:
Copper .00389 (agrees well with the published .00393)
26000 .00144
24000 .00159
