Flow regulator for vacuum pump
I'm looking for a flow regulator for the vacuum pump.
I'm sampling the particules from the combustion source with filter and vacuum pump. However, the pressure drop is getting increased so, I have to monitor and adjust the valve for vacuum pump. Is there any regulator for the vacuum pump then I don't need to keep looking at the valve and pressure?
The system is..
1)Combustion source -> 2)filter -> 3)valve -> 4)vacuum pump.
I would like to put the regulator between filter.
Thanks in advance.
The system is..
Thanks in advance.
RE: Flow regulator for vacuum pump
The valve should being opened when the pressure is getting increased.
