Anybody enjoying NeiWorks?
(this is a duplicate post in the Solidworks forum)
We ended up purchasing a seat of this software, as all our design is done in SWx it just made sense. However, as I'm progressing through FEA I'm becoming a bit annoyed at a lack of functionality. This is mostly on the post-processing side.
The front-end is very nice, auto-meshing will update straight from your design changes. But I'm not even sure if you can query results in SolidWorks, there's some of that in the NASTRAN Editor, but not quite what I had in mind.
Is anybody else using this program, are you having more luck with your results?
RE: Anybody enjoying NeiWorks?
You can give one of us in support a call, or email and we can work out a solution that works best for you.
Mitch Muncy
Noran Engineering Technical Support
http://ww
I just wanted to know if there was some functionality within NeiWorks that I was missing. It seems not too many people use it from what I can tell...
