grouping within sketch
Is it possible to group items within a sketch?
For instance, if the sketch contained:
Circle.1
Point.1
Circle.2
Point.2
Point.3
Point.4
...could I create 2 groups within a sketch such that:
Group1:
Circle.1
Point.1
Group2:
Circle.2
Point.2
Point.3
Point.4
I have a couple sketches with MANY items; this would really help me organize and track within the sketch.
Thanks!
Circle.1
Point.1
Circle.2
Point.2
Point.3
Point.4
Group1:
Circle.1
Point.1
Group2:
Circle.2
Point.2
Point.3
Point.4
Thanks!
RE: grouping within sketch
Why don't you use Layers ?
I'm on V5R15 SP5 on WinXP. In reading other posts on this forum, I was under the impression that we shouldn't be using layers in V5?
That being said, are layers the best way to accomplish what I'm trying to do here?
I've found a workable solution using Selection Sets as a means of differentiating between logical subgroups of all the entities within a sketch, but it's not exactly what I was envisioning.
Any more input?
Thanks...
why layer does not work for you? you can select by layer, filter layers...
you can try also output profil but it might not be good for you...
why do you work in a sketch and not in 3D on support ? then you can use geometrical sets to group your geometry.
Why are your sketches so complicated that you need to group things in them? Knowing nothing more than what I am reading, it appears that there may be a flaw in your design methodology.
I find it so much easier to have MORE sketches, but smaller, and then you can group them externally. As in, naming them, and grouping them in geometrical sets.
But I do believe that there may be more than a few curious onlookers on this topic...
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
I have a series of cross-sections, whose orientations must be driven by each other. Basically, the orientation of elements further down the tree determine the final position of the elements at the top of the tree.
Because of this, using multiple sketches leads to what is perceived as an "overconstrained" situation, as the later sketch is seen as trying to drive the earlier sketch.
Putting all the geometry into a single sketch allows all the elements to properly affect each other.
Is my situation still clear as mud? I'll try to explain more if so...
I really appreciate how much effort ya'all are making to help me out with this.
On the same note, however, I'm not sure that I have the answer that you're looking for.
This brings up an intresting topic. Why do commands that have a completely different function, Have such a similar appearence.
I think I understand your situation, but I agree with Solid7 and suggest using many smaller sketches. Maybe a master sketch could be used to control the features in the smaller sketch?
This doesn't answer your question, but another option you might consider with your complex sketches is something called "profile definition." When you go to use your sketch (for a pad or something); instead of selecting the sketch, right-click and choose "profile definition." A little panel will pop up allowing you to choose a portion of the sketch. Something to consider.
