Phosphoric Acid
Phosphoric Acid
Phosphoric Acid
I need to set up an experiment that will use 1-5% Phosphoric Acid Solution at a temp of 180F and pressure of 2000-4000 psig.  Does anyone know the H3PO4 will gas-off at these conditions or will it be negligible?  (i need to figure out if i need to modify our current vent down conditions or if our current set-up is acceptable)
any help at all on this would be appreciated, even if its just a suggestion on where to begin looking.
Thanks!
RE: Phosphoric Acid
Hot phosphoric was used for aluminum etching in ICs.  Can't remember conditions or concentrations, but this was always done in a fume hood with a scrubber at the other end.
TTFN
RE: Phosphoric Acid
I can guarantee that the vapor pressure of the phosphoric acid is less than 2000psi.  Is that what you are asking?
RE: Phosphoric Acid
H3P04 was used to "glue" the phosphors to the inside
of the neon tubes ( around 1980 ) The pressure was
a few mm. Hg -- evidently the vapor pressure or H3P)4 is much less.
Plesae read FAQ240-1032
<nbucska@pc33peripherals.com> omit 33 Use subj: ENG-TIPS
