Codes governing use of fiber reinforced plastic structural shapes
Are there any codes governing construction of buildings or other structures using fiber reinforced structural shapes?
RE: Codes governing use of fiber reinforced plastic structural shapes
stanweld;
ASME Boiler and Pressure Vessel Code Section X - Design and Construction of Fiber Reinforced Plastic Pressure Vessels
For Repair -refer to the 2004 Edition of the NBIC
metengr,
Thanks for the quick response; unfortunately, that is the Code with which I am familiar.  The codes that I am interested in would govern construction of buildings, bridges, cooling towers, tank supports, etc.
Here is one supplier that we used for structurals around a plant that used HCl. They were very good with information at one time.  The also have a lot of info available on their web site.
http://www.pultrude.com/
Search this site for construction standards.
http://www.acmanet.org/index.cfm
Check out the manuals from Strongwell Corporation.  They have several design manuals with load tables and other information based on their product line.
http://www.strongwell.com/LiteratureLibrary/DesignManual.HTM
In structures there is not a great deal of information as of yet to really have a standard design code.  The ACI has several publications concerning the use of FRP bars for reinforced concrete also, but I don't think they have made it to being called "codes" yet either.
