Bridge Crane Manufacturers who will repond?
I am currently putting an RFQ together for a Bridge crane in a Petrochem facilty. Does anyone have suggestions for manufacturers that could supply a 10 to 18 ton bridge crane? I need someone who can provide a top running and/or underslung crane. This would be supported off of an existing building frame. Also, as an added requirement there is a need for a Class 1 Division 2 Group B NEC compliant crane... Intrinsically safe in an Hydrogen service area. The NEC Classification seems to be the sticking point with these guys... I might as well be speaking Greek to them.
RE: Bridge Crane Manufacturers who will repond?
Zenar
Morris Material Handling
KCI
DeShazo
Ace World Companies
Virginia Crane
try mhia.org/cmaa for more
Try calling some crane manufacturer's main offices (via google) and ask for local reps.
Another issue is your building structure. If it needs reinforcing there's the possibility of all this becoming a significant project.
-Mike
Texas crane builders would not have a problem helping you.
Gaffey, Proserv would be a great start. Sometimes air, in lieu of electric, is the answer in hazardous areas.
