Abaqus/Standard error code 5
Hello
I am using UMAT subroutine in forming analysis. It is running well in Explicit and Standard with the simple geometry that it has been sent with. It is also running in Explicit with my application. I have a trouble with running my application in Standard. It is giving me the error code 5 "Access is denied" and following
ABAQUS Error: The executable C:\ABAQUS\6.5-1\exec\standard.exe
aborted with system error "Access is denied.
" (error code 5).
Please check the .dat, .msg, and .sta files for error messages if the
files
exist. If there are no error messages and you cannot resolve the
problem,
please run the command "abaqus job=support information=support" to
report and
save your system information.
There are no errors in those files
I will appreciate any help with this problem.
Lina
RE: Abaqus/Standard error code 5
Hello, I got the same problem in standart. Could you solve the problem now?
I have also just started running into this problem.  Mine seems to occur when I have multiple material types and interactions in the same model.  If anyone knows anything PLEASE SEND HELP!
Brian
Could be an OS problem?  Are you running out of disk space?  Are you writing to a directory that you don't have user permission for?
Could be time to call ABAQUS perhaps.
Martin
I could solve the problem by using the new version of ABAQUS 6.6-1. There no error message when you convert the whole model into v6.6-1 an run it in CAE.
It is may be not the finest way of solution but I am sure thats it is not a problem of disc space or permission.
fox
