Material for Bearing Driver
I need to make a custom bushing driver. I am considering using ASTM 4140 material? Any other material I should be considering? Should it be hardened and too what degree?
Thanks for your help
RE: Material for Bearing Driver
What is the function of a custom bushing driver?
Will this driver be a one time use tool, or one that will see frequent usage?
The function of the driver is to install a bushing into the arm of steer knuckle at the proper depth with out distorting the bushing. It is not a one time tool, but daily usage.
Why not try 4140 Q&T to 30/36 HRC (commerical heat treat)?  If it wears out too quickly, try a tool steel.
rp
redpicker's advice is appropriate.
Cory
Using annealed S7 would probably work as well. It would work harden on the contact surfaces quite quickly and would be less prone to craking/shattering caused by pressing on hardened steel.
Nick
"Speed costs money boys, how fast do you want to go?"
I wouldnt use annealed tool steel. The tool steels are properly used at a Q&T condition.
30/36HRc is relatively tough and has a tensile strength ~150ksi. There should be no problem with cracking or shattering.
If the tool shows deformation after 1-2 uses you could try a tool steel. Since you are not hammering the bearing in you could use a common steel like O1. (Q&T to 45-50HRc giving ~231ksi strength)
Nick
I love materials science!
