Milling carbon filled UHMW
I'm looking for any suggestions on milling carbon filled UHMW.  The problem we are having is that the chips aren't clearing, and just "fuzzing" up.  Using a 2 flute 0.218" dia ballnose cutting 0.046" dp with the tip, our max spindle speed is 5k and thats where we are running.  I think the main problem with the process is that we are using a rotary table (max 15rpm rotation) to change part orientation during cutting, and the geometry dictates a feed of 3 ipm due to the ro-tab.
I am considering a vortex tube cold air gun, but don't think it will have sufficient velocity to blow the chips out before they re-weld theirselves back to the stock mat'l.
Svanden
RE: Milling carbon filled UHMW
Vortec cooling would certainly be something to try and it uses a relatively inexpensive device, the cost being the compressed air to power it.  We have used up to three devices at a time on a  milling machine.
One other method we used for machine cooling where we needed a large volume of cold air was a modified industrial spot cooler.  I don’t see why one of the portable room air conditioners couldn’t be modified to cool the machining operation.
http://www.itw-air.com/index.php
http://www.portablecooling.com/portable-air-conditioners/air-boss.php
We tried a cool tube about an hour ago, and it worked just fine.
