Importing Assemblies to ANSYS
I have a model generated in solidworks, made of several beams (parts) that I latter used to buit the model in an assembly. The beams are supposed to be welded between them. What should I do after importing the model to ANSYS? Is it only necessary to VGLUE the beams?
RE: Importing Assemblies to ANSYS
Or you can use VADD (removes internal boundaries), depends on how you want to maintain your geometry. You can also specify tied contact to achieve the same thing.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
