ACAD - 2005 - CHANGING LAYOUR COLOUR
I have a programme which runs behind Autocad to produce plan and profil drawings. Its fine apart from when I draw the profil to autocad some of the layers are set by layer to a colour that is just not good for presentation. The package does not allow for a change to this colour.
I want to use toolpallets to bring up a LSP routine to change those 2 layers to a color which I have already decided and will always be the same (253 and 4).
Can anybody help with a routine.
RE: ACAD - 2005 - CHANGING LAYOUR COLOUR
if You want to take a commandmacro, You can use:
CODE
The colour of these objects is still "by layer". It is changed in the layerproperties...
HTH, Lothar
ADT 2004
ACAD 2002
