Stainless Material Selection for Fastener
Dear Forum:
I am working on a fastener design, and I am trying to select the proper grade of S/S. Here are some of the restraints:
1.) The fastener is to be machined(screw machine or CNC lathe) from 5/16 dia. bar stock
2.) The required tensile after machining needs to be b/w 145-175 ksi
3.) I'd like to avoid heat treating if possible (mainly to cater to the cosmetic requirements i.e. the fastener needs to blend in color with mating 303 S/S parts) Heat treating is an option if there is a way to prevent discoloration.
I've tried 303, and 304 in the annealed condition and the tensile is not quite enough. If someone offered 303 bar stock in the 1/4 or 1/2 hard condition, this would most likely solve the problem. Any guidance would be much apreciated.
Jason
Jason
RE: Stainless Material Selection for Fastener
