Polishing clean condenaste
Does anybody have an experience with polishing both clean and suspect condensate?
There are some plants polishing both and some only suspect condensate.
What is your experience?
Cheers
SmartEngineer
RE: Polishing clean condenaste
It depends on your steam pressure, the heat flux in the steam generator and what you are using the steam to drive or heat.
A high pressure steam generator operating at a high flux rate to produce superheated steam to drive a large turbine would be an obvious candidate.
Thanx
The steam generated is HP steam by steam boilers and using it for driving turbines, and heating medium for heat exchangers
Cheers
