Corrosion of Electrostatic Precipitator
Does anyone have experience with corrosion of the separation plates in an electrostatic precipitator downstream of a spray dry scrubber (for SOx removal)?
What is the role of chlorides in corrosion downstream of the scrubber?  The scrubber makeup water is the salty reject water from a reverse osmosis system.
Thanks.
RE: Corrosion of Electrostatic Precipitator
What are the temperature regimes in the area of corrosion, the metallurgy of the ESP system plates, and the chloride concentration of the makeup water?
Orenda
