Corrosion of Electrostatic Precipitator
Does anyone have experience with corrosion of the separation plates in an electrostatic precipitator downstream of a spray dry scrubber (for SOx removal)?
What is the role of chlorides in corrosion downstream of the scrubber?  The scrubber makeup water is the salty reject water from a reverse osmosis system.
RE: Corrosion of Electrostatic Precipitator
What is your material of construction?
There is a good reason that these are usually either high alloy stainless or Ti.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
