Inflection Point Lateral Bracing
I've heard many times that a moment curve inflection point can be assumed to be a brace point when considering lateral torsional buckling. I have recently come across a case that calls that assumption into question.
Have any of you done laboratory experiments on this phenomenon or know someone that has? I understand that many of you may have successfully used this assumption for many years, but I'm looking for someone with definitive test experience to discuss this with.
Thanks.
Thanks.
RE: Inflection Point Lateral Bracing
I do know that many engineers over the years did take the distance from the column support to the inflection point as an unbraced length lu in ASD and use that for the adjoining negative moment...along with Cb = 1.
I was at a seminar in the early 80's when Yura was asked this question and I believe he answered "yes, as long as Cb = 1 you are generally conservative doing this". However, it subsequently came out that there are some cases, with particular parameters, where it wasn't conservative.
We used to take the IP distance x 1.2 and use that to be extra conservative. But this was based on engineer's response to silence in the AISC specification about this situation.
Today, I use the full length with the proper Cb.
Also - you can add bottom chord braces near the IP and definitely use the shorter length.
