backgound color
backgound color
WHERE IN THE CUSTOMER DEFAULTS DO I CHANGE THE BACKGROND COLOR - WINDOWS-NX4
THANKS
THANKS
RE: backgound color
->Check which is your default file from ugii_env.dat,it may be ug_metric.def or ug_english.def.
->Make changes in these file in the required area and will be applicable for all new files you create
RE: backgound color
Now, in order to change the background color in NX3 (I don't have NX4 installed, but I assume it hasn't changed), you need to start NX, then when you're at the No Part State, choose File -> Utilities -> Customer Defaults to bring up the Customer Defaults dialog. You will need to decide how you wish to admin your defaults. You can set them at a site, group or user level. Once all that is done, click on Visualization on the left side of the dialog and you should now see a Background tab on the upper right side (near the middle). Click the Background tab and there you are. Set your background however you wish and then OK out to save the defaults (if you have permission to change them).
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: backgound color
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP3.3 on WinXP SP2
RE: backgound color
RE: backgound color
This is all covered quite well in the documentation.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: backgound color
It is file specific (if it's an existing file). All new files will read from the Customer Defaults options.
RE: backgound color
Spottydot,
You didn't specify whether or not you were wanting to change the background color of an EXISTING file or all NEW files (when you click File -> New). Yes, it does make a difference. The customer defaults route ONLY changes the background for NEW files. If you wish to change the background of an EXISTING part file, you need to bring up Visualization Preferences.
To do this, open your part file and select Preferences -> Visualization and this will bring up the Visualization Preferences dialog. Click on the Color Palette tab and at the bottom there are 2 buttons, Edit Background and Edit Color. Select Edit Background and change the colors as you wish then SAVE the part to save the changes you've made. Keep in mind THIS DOES NOT CHANGE ANYTHING FOR NEW PART FILES, IT ONLY CHANGES THE SINGLE PART FILE IN WHICH YOU MADE THE CHANGE. If you wish for all new parts to have this background color, then you MUST do it from the customer defaults menu as I outlined before.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: backgound color
RE: backgound color
RE: backgound color
Are you clicking on plain under Shaded views and Wireframe Views? Also, what level are you on? Site, group or user? And you have access to change site and group?
RE: backgound color
RE: backgound color
1 - Preferences --> Visualization --> Color Palette
2 - Edit Background color
3 - Select Black
4 - OK
5 - Save CDF as...
6 - File --> Utilities --> Customer Defaults
7 - Gateway -- Visualization --> Color Palette
8 - Windows --> Browse --> select location of the saved custom CDF file
9 - OK
10 - Close UG
11 - Restart UG
12 - File --> New
RE: backgound color
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
RE: backgound color
RE: backgound color
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
