Revision Table
Revision Table
When inserting a Rev Table the row height will default to .34 we want it to be .17. Is there a way to get the template to save the row height that is entered. I have adjusted the Rev Table with the info I want and did a save as template by right clicking, but the row height defaults back to .34, am I missing something?
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
RE: Revision Table
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Revision Table
We have had the same problem. Solidworks lists SPR #280436 and that is fixed that with SP2 in 2006, but we still have the problem. Notified our VAR again and they were checking into last I knew. I don't know of anyway to correct it. Our row height comes in at .355, no matter what gets done to the template.
mncad
