How to open prt with out opening the asm?
Every time i open a prt, the assembly from which it was derived opens with it. Is there a way to abort this process? (the "cancel" dialog is not available until it is too late)
RE: How to open prt with out opening the asm?
To fix your problem you may want to have the option for loading referenced documents set to NONE. Hope this helps!
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
