Can't open tutorial files
When I try to open any of the tutorial prt files in the educational version of wildfire 2.0 I get the error message ' file was created with a commercial version of Pro-Engineer and is not compatible with the educational version' is there a work round for this?
RE: Can't open tutorial files
Depending on the tutorials you are using, there may be educational version files available. If you are using the WF2 Hands on Workshop (HOW) files, I remember there being two versions of these demo files. Dig through PTCs site and you should find it.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
Prowd
