displacements on a straight line and thickness for a 2D
In the case of a 2D unit cell (for example rectangular):
1.how to impose a thickness (of 1mm for example)?
2.in applying a pressure on one side, how to impose that all the nodes of this side have a displacement as a straight line? (complete procedure)
RE: displacements on a straight line and thickness for a 2D
Most FE pograms should be able to do it automatically, and it is not clear if you want to do it manually.
