Need CS lining or coating method to resist seawater corrosion
We have a OSBL sub-project of pumping seawater via CS pipeline. I want to know a safty and pratical method for lining  and/or coating.
RE: Need CS lining or coating method to resist seawater corrosion
What kind of Q's and pressures?
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Thanks a lot!
The flowrate is 27000m3/h, the design pressure is 0.6 MPa.
Coal tar epoxy lining will work in this application. The thicker the coating, the longer the survival of the pipe.
Have you looked at GRP or HDPE?
WWW.amlinereast.com
You should be okay with coal-tar epoxy, how long a run is it? The other thing might be to slipline it with HDPE.
