dB per octave spec with a ASD curve
When someone specs 2dB or -2dB 'per octave' in the context of acceleration spectral density, what does it mean graphically?
Tunalover
RE: dB per octave spec with a ASD curve
If you plot db versus log frequency it should drop at 2 dB per doubling of frequency, in a straight line.
Cheers
Greg Locock
Greg-
dB is a log of a ratio...but what is the ratio in this case?
Tuna
Tunalover
Referenced to your reference value (!). Won't actually make any difference to the slope.
Possible  reference value for an asd would be 1 g^2/Hz but you'd get very negative values. Don't get caught out by the difference between 10 log and 20 log for your dBs.
Cheers
Greg Locock
Thanks Tom Irvine!
Tunalover
