Holes
Holes
After drawing a round bar 37mm long x 19.05 dia and a hole 6.35mm dia through middle and c/bored 9.52 dia x 20mm deep , i then proceed to put drilled and tapped m4 holes in one side. How on earth do you dimension these holes (pitch)after they have been put in ???
RE: Holes
Try going to INSERT/MODEL ITEMS, in the property manager click the dimension panel.  Then in the view of your drawing click the feature.  This put in your drawing the locating dimensions that you used in your model
RE: Holes
You don't dimension them after putting them in, you do it while you are placing the points.
How Do I Use The Hole Wizard On A Cylindrical Face?  FAQ559-1150
How do I create an angled hole using the Hole Wizard  FAQ559-1156
Also if you have multiple holes, it is often better to place just one, and then use a feature pattern to place the others.
It is easier to manipulate the feature pattern, rather than the HW sketch.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Holes
On the dwg view, dim the thd i.e. "2X M2 (whatever the call out is) THRU (or DEPTH sym)".
Chris
Systems Analyst, I.S.
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
RE: Holes
Thanks to you all. I got there in the end with a bit of this, that and the other.
RE: Holes
Yeah ... a bit of the other always helps. tongue
cheers
RE: Holes
You can also open the feature in the property manager to reveal the generated sketch and then edit the sketch
RE: Holes
Yes , that was one of the things i came across , thanks.
