Wastewater Treatment
I am looking for advice on where best to start research into wastewater filtration or treatment systems.  The wastewater is from a precast concrete waste crushing system - the water is full of cementitious and aggregate material and needs to be cleaned prior to discharging into storm system.
RE: Wastewater Treatment
You probably just need pH adjust (acid feed) and a gravity plate settler (clarifier).
Suggest you contact a manufacturer of this gravity plate settler for further information.
