Copy and Paste - Excel to Word
I've had this problem before and I don't think I solved it then. I'm trying to copy a table from Excel to a Word document using paste special. If I choose to paste either as a 'picture' or as an 'object' the final few rows don't appear. If I insert an additional row into the middle of the table then it truncates the next row at the bottom when pasted, so it seems to be limiting the size of the paste area in some way, although it doesn't fill the page by a long way.
If I paste as a 'bitmap' it produces the complete table. Does any body know the reason for this, as it's only now and again that it seems to occur?
Cheers.
Cheers.
RE: Copy and Paste - Excel to Word
Am I missing something?
You're not missing a thing.....Ctrl C, then Ctrl V works like a charm!
Orenda
Paste-special / worksheet object preserves the formula's. You can double click to open this object as excel spreadsheet within word and make any future changes as needed.
Ctrl-v (normal paste) pastes only the results.
If all you need is the results, use ctrl-v.
If you want the spreadsheet, continue using paste special. Then you may need to double-click the pasted spreadsheet to open from within word. Drag the corner to make sure the number of rows/columns you want are displayed.
Right you are! Thanks for the tip/correction.
Orenda
The problem I have with using the simple cut and paste (Ctrl C and V) is that it simply reproduces the Excel cells in Word table format. When the table is to big to fit in side the page borders you have to scale it down by adjusting the individual row and column width/heights, which is a lot of extra work when you have to produce fifty odd tables. There doesn't appear to be a way of scaling down the full table by a single reduction factor as you can with say a 'picture' or 'bitmap'.
Pasting it as an 'object' is ordinarily fine apart from what seems to be in this case. If I single click on the object I can adjust the dimensions of the 'border', but this simply shows the same data only larger or smaller. If I actually open up the object inside Word, horizontally I can expand/reduce the viewing area to see more or less data. When I try this vertically, I can expand it to see more data, but when I let go of the drag button it shoots back to its original position I start from. Basically there just seems to be like an invisible buffer preventing the vertical height increasing and staying there. I've taken off the 'lock aspect ratio' prior to opening up the object bur it didn't make any difference.
I don't see this as being a problem easily replicated as this is only the second time I've come across this in years of writing reports.
Cheers
I have never experienced the problem of going back to original size. But sometimes I do lose one row off the bottom. I think it may have something to do with a difference between how word and excel treat the font size. If I lose a row off the bottom I just reopen in excel and drag down to get one more row. Like you I have also been working with excel objects in word and powerpoint for years...I have never had one that I couldn't fix this way.
Maybe I have not understand the question, but if the problem is space (final rows missing), and as say richardmorris:
'When the table is to big to fit in side the page borders you have to scale it down by adjusting the individual row and column width/heights, which is a lot of extra work when you have to produce fifty odd tables.'
In the speadsheet you can select the rows and columns that you wish to paste and change there the size of row/column in just a couple of clicks.
Then just copy-paste as you want
Hope this will help
Should have mentioned I was using word 2000, my fault.
I use Word 2000 as well but I have never put that big of a spreadsheet into it. It's good to know the nature of problems I can expect if I try it.
Cheers,
Joerd
In Excel, highlight the portion you want, then holding down the shift key, open up the Edit menu and select "Copy Picture...". You even get to choose if you want the screen version or the print version!
Then in Word, just Paste, and voila, a picture of the spreadsheet that can be stretched, cropped etc. and prints really well!
I don't know why Micro$oft hides this powerful feature.
tg
Thinking in how to paste... This is a litle long or complicated, and even not usefull, but well.
In the preview of the spreadsheet, you have a configuration button where you can select the size or zoom (%) of the spreadsheet to print (maybe in file -> page format you can find the size), so if you print it in adobe format (you need an adobe printer) you can select the table in the adobe document (so, you need to have the no-reader adobe) and paste it in the word file.
Long and strange.
Anyway, hope this will help
trainguy:
I have not tried your tip yet, but it looks very interesting. Thanks.
You might look at your Word Paste Settings.
I don't know if this will help, an experiment may show whether this makes any difference.
In the tools menu: "options" and then select the Edit tab.
Go to "settings":
Go to "Adjust format when pasting from Microsoft Excel."
The context help advises:
JMW
www.ViscoAnalyser.com
Thanks for the suggestion, but I'm using Word 2000 and 'settings' doesn't appear on the edit tab. I aasume this option is given on 2002 onwards.
Cheers.
