End Returns & Footing Reinforcement
Are end returns only necessary for Temp/Shrink reinforcement in foundation design?  If you have full development length for your flexural steel from the column face, there is no need to hook the bars right?  Also, can you use the (As req'd/As provided) reduction factor on the development length for flexural steel?
Thanks in advance,
Lee
RE: End Returns & Footing Reinforcement
XBLEE,
Seems like a question better suited to the Structural Engineering fora on engtips.com.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
The views or opinions expressed by me are my own and do not necessarily reflect the views or opinions of my employer.
Thanks, I'll repost.
