Macro Intermittent
Macro Intermittent
Macro Intermittent
I have created a macro that will take a model view and insert it on to our DXF drawing sheet and will do a save as and save it to the user specified location. On some computers the macro runs without any issues on some other computers the macro fails to create the DXF and save it to the location specified. Has anybody had this happen with their macros? If needed I can post the code so the experts can go through it.
Don't worry about people stealing your ideas. If your ideas are any good, you'll have to ram them down people's throats.
--Howard Aiken, IBM engineer
RE: Macro Intermittent
Yes, post the code. However, always check the file location with code in the macro to see if the directory is on the hard drive. If not then create the directory.
Bradley
The file is always saved in an already created directory across the network, so creating the directory is not needed. I have attempted to save the DXF on a local hd and on a network drive on some computers and it does not work.
Dim swApp As Object
Dim Part As Object
Dim retval As String
Dim modeldoc As Object
Dim strPartName As String
Dim strPathName As String
Dim strDrawName As String
Dim strSavePath As String
Dim View As Object
Dim bolMapping As Boolean
Dim intScale As Integer
Private Sub cmdBrowse_Click()
strSavePath = GetDirectory
strSavePath = strSavePath & "\"
txtPath = strSavePath
End Sub
Private Sub cmdCancel_Click()
    End
End Sub
Private Sub cmdOk_Click()
'Update Save Path
    strSavePath = txtPath
    SaveSetting "CreateProfileDWG", "General", "SavePath", strSavePath
'Connect to Solidworks
    Set swApp = CreateObject("SldWorks.Application")
    Set Part = swApp.ActiveDoc
    Set modeldoc = swApp.ActiveDoc
'Find File Name
   strPartName = modeldoc.GetTitle()
   strDrawName = Replace(strPartName, "SLDPRT", "dxf")
' Create Drawing
    Set Part = swApp.NewDrawing2(swDwgTemplateCustom, "G:\~ENGINEERING\solidworks templates\DXF Template.drwdot", 6, 0.297, 0.21)
    retval = Part.CreateDrawViewFromModelView(strPartName, "Current Model View", 0.1449224704336, 0.0999914586071, 0)
    Part.SetupSheet4 "Sheet1", 6, 13, 1, 1, 1, "*.drt", 0.297, 0.21, "Default"
    Part.SelectByID "Drawing View1", "DRAWINGVIEW", 0.2510516302174, 0.07917764706756, 0
    Part.ViewZoomToSelection
'Set export options
    bolMapping = swApp.GetUserPreferenceToggle(swDxfMapping)
    swApp.SetUserPreferenceToggle swDxfMapping, False
    intScale = swApp.GetUserPreferenceIntegerValue(swDxfOutputNoScale)
    retval = swApp.SetUserPreferenceIntegerValue(swDxfOutputNoScale, 0)
'Save Drawing
    strSavePath = strSavePath & strDrawName
    Debug.Print "Full Path = " & strSavePath
    retval = Part.saveas3(strSavePath, 0, 1)
    currentdoc = Part.GetTitle
    swApp.CloseDoc currentdoc
'Return export options to orgionals
    swApp.SetUserPreferenceToggle swDxfMapping, bolMapping
    retval = swApp.SetUserPreferenceIntegerValue(swDxfOutputNoScale, intScale)
    frmMain.Hide
End Sub
Private Sub Label1_Click()
End Sub
Private Sub OptionButton1_Click()
End Sub
Private Sub txtPath_Change()
End Sub
Private Sub UserForm_Activate()
'Get save path from registry
    strSavePath = GetSetting("CreateProfileDWG", "General", "SavePath")
    Debug.Print strSavePath
End Sub
If it's consistently the same computers on which it doesn't work, then it's probably not the macro. It is more likely to be a setting or program on the "rogue" computers which is blocking the macros actions.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
