Vapor Pressure n methyl pyrrolidone
I need the VP of n methyl pyrrolidone at 100F, and preferably over a range of temperatures from about 75 to 125F.
Anyone know where such data might be found?
RE: Vapor Pressure n methyl pyrrolidone
ht
If you google it, there's also vapor pressures at 68F. Put them in an excel spreadsheet and curve fit them remembering the log of the vapor pressure is proportional to the reciprocal of the absolute temmperature.
You can do the same with the data in the CRC Handbook of Chemistry and Physics.
