Copying Part Bodies to Another Part
Is there a way of copying a Part Body from one Part to another and taking all the associated geometry with it? I don't want to paste it with a link back to the old part and I dont want a dumb solid.
RE: Copying Part Bodies to Another Part
File -> New From (select file you want to copy from)
1) Delete all unwanted solid bodies
2) Tools -> Delete useless elements
3) Everything that remains gets selected, copied and pasted
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog
I think I know what the answer is - use Hybrid Design. In this instance the solid and all the geometry associated to it are created in the same Part Body and can be copied and pasted into another Hybrid Part. But if you don't use Hybrid modelling and the solid's parent geometry is contained in a Geometric Set it doesn't work. CATIA doesn't seem able to gather all geometry together to enable a copy / paste operation unless thay are all in the same part body.
If deleting all solid bodies, (except the one that you want to use) and running "delete useles elements" is too difficult, then I'm not sure that I understand what you're after.
It would be ideal if you could copy, with the same sort of logic that goes into moving elements between geometrical sets - i.e., the "move unshared parents" - but I don't think that's feasible for a non-hybrid design, as you've mentioned.
Good luck.
Yes, it creates a new part. One that you can tear apart, risk-free. You keep only the info that you want before copying and pasting it where you want it.
Again - with the new part, delete ONLY the solids that you don't want, and then run the "delete useless elements" command. Whatever is left, move into one geometrical set, if necessary.
Finally, copy and paste whatever is left. It will be logically organized, and you don't have to lose it in the mess of the rest of the tree.
