Local and Derived Patterns
Can you change a local pattern and make it derived and vice-versa?
I am working on an assembly created by someone else and he has a derived pattern of screws going through a hole pattern but he created a local pattern of the t-nuts that the screws also go into.
I would like to change the t-nuts pattern to derived so that I only have to change the parent pattern to completely modify the assembly.
John
John
RE: Local and Derived Patterns
That is what I have already done. Sometimes I find myself trying to make things harder than they need to be.
John
