Calcs for powered roller conveyor
I am trying to find a formula for calculating the motor required to drive a 1 metre chain driven roller conveyor. Maximum load is 25Kg and roller width is 450mm
RE: Calcs for powered roller conveyor
Procedures for calculating the power requirements can be found in:
"Belt Conveyors for Bulk Materials"
Published by Conveyor Equipment Manufacturers Association
Chapter 6 - Belt Tension, Power, and Drive Engineering
