Sourcing vs Sinking outputs and CE
I read somewhere that CE requires that PLC output logic be PNP (or sourcing)? Is this accurate? I believe that the applicable standard is IEC 61131-4, though I don't have a copy of it
RE: Sourcing vs Sinking outputs and CE
You might try this website to get some insight on this standard - http://www.plcopen.org/
Also, inputs are fail-safe when using positive (PNP) logic. A loose wire will not start anything in such a system while it can be seen as a logic one in an NPN system where inputs are closed to ground.
Gunnar Englund
www.gke.org
Are you sure about that?
And, are you in Europe or somewhere else?
Gunnar Englund
www.gke.org
