Documentation for command line installation
Does anyone know where I could find the documentation to load Dassault suite from the command line or in a batch file mode?  I'm interested in loading the Multi Cad Plugin for Unigraphics.
Thanks...
Fighter Pilot
Manufacturing Engineer
RE: Documentation for command line installation
What is "Dassault suite"?  I did a Google search for it, and I can find any contextually appropriate results to describe what you might be speaking of....
I don't know about "Dassault suite", but I can tell you that the Pro/E MultiCAx plugin is a $4500 (+ 12% annual) option.
Professional and reliable CAD design engineering services - Specializing in Catia V4, Catia V5, and CAD Translation.  Catia V5 resources - CATBlog
Oh - I thought you meant something else. (sorry - not use to hearing other users use the term)
Anyway, if you already have the disks, and you are reinstalling to add the functionality, (based on a previous custom installation) you just simply need to run the setup.exe file, located in the root directory of the install CD.  I'm guessing that you are asking because the AUTORUN.inf file didn't work?
I believe that you have to uninstall your previous installation first, but I'm not 100% certain for the MultiCAx plugins. (workbenches, yes)
fighterpilot (Military)
I think I've located it in the help files under Catia Infrastructure.  I'm specifically looking at the installation of the program w/o graphical user interface.  i.e. startb command.
thanks...
Fighter Pilot
