motor parameters
motor parameters
Hi!
I´m looking for any webpage were I can find examples of the equivalent circuit parameters, but I cant get them.
Does anyone know were can I find them???
Thanks in advance.
Martin
Thanks in advance.
Martin
RE: motor parameters
Also check-out the NEMA web site.
Yours
So I was looking for any webpage that has laboratory tests.
thanks again
You could also look at the default parameters in open loop vector drives as an indicator. The drives have a look up table based on typical values which are then tuned by the setup mode and can be programmed by the operator if they know the actual values.
Best regards,
Mark Empson
http://www.lmphotonics.com
Motor parameters can be found at, for example:
small motors
http://russellmetalproducts.com/Motors.htm
http://www.jl-motor.com/html/ms.htm
larger motors
http:
