speed governor
speed governor
what type of fire suppression system can be used to protect electronic speed governeor.
any help/advice it would be greatly appreciated.
RE: speed governor
RE: speed governor
http:
RE: speed governor
1. If the risk is within the pannel and you want to prevent damage on it on a early response basis: think of locating a smoke sensor in it or a more complicated detection system like VESDA (look f this on the webb). Sometimes you can buy the equipment with a smoke sensor in it or asking for premission of the manufacturer to install one or a VESDA system. A detection system would be good only if you can provide an effective response to shut down the power or extinguish the fire.
2. If the risk is outside the pannel and the place is closed, think of an clean agent system for the room.
3. Locate a smoke sensor above the pannel.
4. Look for specific requirement on an NFPA specific for the facility or FM standard.
