Trimming a pin to a surface.
I am trying to trim a pin to a contoured surface in my model with out success.
The pin was created using the revolve sketch command.
The cut with surface icon is available but once i select it I cannot select my pin or surfaces around it.
There is also a clearance hole through the part for the pin.
The trim surface icon is greyed out.
any suggestions.
[URL=http://i mg53.image shack.us/m y.php?imag e=pintrimm ing3an.jpg][IMG]http://im g53.images hack.us/im g53/7999/p intrimming 3an.th.jpg[/IMG][/URL]
any suggestions.
[URL=http://i
RE: Trimming a pin to a surface.
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP02.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
www.Tate3d.com
Because now the pin is a revolved sketch.
Here is the view of the model along with the directory tree.
[IMG]http://img
Lava Lamp
www.Tate3d.com
You should then be able to cut the pin with this surface body.
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
I ended up doing a surface fill which intersected the full pin diameter.
Afterwards I did a surface offset up .040 and then back as suggested.
Next I noticed some of the trim commands were nolonger greyed out which was nice to see.
And finally I was able to use that surface fill to trim my pin it was a beautiful thing!
See for your self [URL=http
