compress a tube in solidworks
I drawn a bended tube in solidworks06. Now I want to compress the bended end of the tube together. How can I draw this?
best regards
RE: compress a tube in solidworks
If you made the tube by sweeping a profile along a path... I would suggest adding a loft to the end of the "tube" & loft it to a "compressed" profile.
Windows 2000 Professional / Microsoft Intellimouse Explorer
SolidWorks 2006 SP02.0 / SpaceBall 4000 FLX
Diet Coke with Lime / Dark Chocolate
Lava Lamp
www.Tate3d.com
okay thanks,
but how can I make a loft that is not filled in the middle. I can select two regions(the pipe) to make the loft, but when actually creating the loft, solidworks gives an error.
You can always do a Shell after the loft, or
Create inner & outer start & finish profiles of the pipe, & loft between those, or
Create a solid sweep & loft first, then do a shell on both.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
You can also use the Deform feature to bend the pipe after creating it in its normal size/shape.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
