expanding gate valve
hello all,
I am doing a surge analysis on a procss line.
Is the Cv values are different for normal gate valve and expanding gate valve.
Do they behave different at valve closure.
Also Can I use "surge pressure+operating pressure" for max shut off pressure for a valve actuator selection.
Thanks in Advance
Best Regards,
Prens
Thanks in Advance
Best Regards,
Prens
RE: expanding gate valve
Most likely the Cv values will be different. You should look in the manufacturer's data to see what the Cv value is for each type of valve. You may also need to contact the manufacturer. I would presume that the valves would behave differently at valve closure, but really don't know. Again your best source would be the manufacturer.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
