Pole-mounted OHL predictive method
Dear guys,
I know there are applications of fault indicators hanged on each phase conductor which ignite in case of fault/open conductor. Is there any embedded products or design sensing positive-, negative- and zero-sequence current and analysing electrical signature to give predictive alarm in case of deteriorated line? Thank you in advance.
SCADA
