Piezoelectric/Acoustic Analysis
I wish to model the acoustic pressure fluctuations generated in a chamber due to a piezoelectric actuator. How do I transfer  the resulting displacements of piezoelectric analysis as loads  to the acoustic analysis. The LDREAD command does not have displacement as a load label. Could anyone upload an example if you had worked on a similar problem. Thank you in advance.
