Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I always seem to find what I need in previous threads without starting my own. I have started a couple but that's it..."
Geography
nbucska (Electrical)
22 Feb 06 11:57
I have to write a program which extraxts alphanumeric info
from one or more single or multipage EXCEL files and convert them to ASCII format for further processing.
Any help is welcome.
<nbucska@pc33peripherals.com> omit 33 Use subj: ENG-TIPS
Plesae read FAQ240-1032
IRstuff (Aerospace)
22 Feb 06 12:01
not sure I follow.  Excel can save to comma delimited format (CSV) files.
The other brute force approach is to copy/paste into Notepad.
TTFN
22 Feb 06 12:51
Comma delimited won't work - the text may contain comma
Tab delimited can't convert multiple pages -- must do manually.
Neither one can convert multiple files
analogkid2digitalman (Electrical)
22 Feb 06 13:16
Sounds like a potential application for Excel's internal Visual Basic for Applications programming language. I know it has functions for iterating through "Each Workbook in folder xxx" and "Each Sheet in Workbook" and also funtions to identify each nonblank cell in a sheet.
A google search might even turn up an almost ready made solution.
"It's the questions that drive us"
IRstuff (Aerospace)
22 Feb 06 13:29
Then copy/paste is the only approach, wrapped by a VBA macro
TTFN
WHRVSC (Marine/Ocean)
7 Jul 06 11:40
I'm afraid this is a little late, but I just saw your post.  Have you tried using the Data/Import External Data/New Database Query.  It uses MSQuery to pull the data from a database.  It can be setup to use an Excel Database as its source.  The Queries can be refreshed either at document open, via a macro or manually.  Hope it helps.
ROBERTDION (Computer)
23 Aug 06 10:05
i have a programming software that can do the kind of thing you want to do. It's Windev from Pcsoft. It's very easy to manipulate xls files.
Close Box
Join Eng-Tips® Today!
Join Us             Close
