Wanted: Steel Beam Web Opening design software
Does anyone know of a software package which does web opening design in steel beams?
Thanks in advance.
Andrew
Thanks in advance.
Andrew
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Wanted: Steel Beam Web Opening design software
Thanks very much for the quick replies.
I also found out that AISC has a program which is $330 for members, but it is old DOS based.
I have a couple roof girders which have holes in them at regular spacing for AC duct. I am concerned about beam deflection overall with multiple openings. A single opening does not concern me too much, btu multiple can add up the extra deflection quickly I think.
thanks again.
Andrew
Unfortunately for you both of these programs only take strength desing considerations into account and neither takes into account the effect these openings have on the deflection of the beam. The AISC Design Guide goes over a few different methods to approximate this deflection. Also using the FE method to explicitly model the beam with openings for deflections is always an alternative.
