Glued Laminated Appearance Grade
The project is a church. Ninety percent of the Glulam members are exposed. Ten percent of the glulam members are concealed above a dropped ceiling, soffit or elsewhere.
I am aware of (4) appearance grades: Industrial, Industrial S, Architectural and Premium. (What is "Industrial S"?)
I am specifying the Appearance Grade to be "Architectural". Is there a cost benefit in specifying the concealed ten percent as Industrial, or is the cost savings little to nothing?
Thank you!
Thank you!
RE: Glued Laminated Appearance Grade
https
Some of the savings for the 10% members not exposed is balanced by the risk of mixing locations. Cost out the two options and decide.
