Remember Matings : how do I unset it ?
I have an assy where a 'remember constrains, has been set to a washer. Now, I want to mate that washer in a different way, but I'm always proposed the same old mating pattern ...
Is there a way to remove that link between the washer and its forced mating procedure in the assy ?
I'm using NX2.
Thanks.
I'm using NX2.
Thanks.
RE: Remember Matings : how do I unset it ?
Goto File->properties, under the Part File tab you can delete all or some of the remembered mating conditions.
Then you can chose the mate icon or select the component and choose Mate from the pop-up and you don't get prompted for the default assembly constraints.
Michael
As such the option suggested by mjcole is probably better as it will allow you to place your component near its final position. You can then mate it afterwards.
